Old 06-12-2013, 03:38 AM   #18 (permalink)
aktacoma
EcoModding and having fun
Ol' Honda - '84 Honda Civic 1500 S
90 day: 37.03 mpg (US)
Originally Posted by a8ksh4 View Post
aktacoma, I haven't seen mine above 198 degrees on the scanguage. I'm inconsistently trying to remember to watch it. I haven't looked, but isn't there a wire on the clutch for the belt driven fan that we could use to trigger the electric fans?
I'm not sure what you mean but I'll look into it I'm experimenting now trying to cut my grill block enough to make the truck run cooler but if I was to do it again I would just use an in cab switch and monitor coolant temps because as of now it likes to come on then off then on even after I shut the truck off! I also just might buy a bigger fan to push more air through it.
by the way hows your topper going?
