Old 06-15-2013, 09:07 AM   #3 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Exhaust is hot, but is it hot enough? I'm not smart enough to have that kind of math in my head, but if you want decent power out of a Stirling, it's all about the delta-T. Lower temperatures require larger heat exchangers, larger displacer pistons, and generally lower revs. You might wind up going backward in terms of efficiency.
It might be easier to just stick a hundred Seebeck devices onto the exhaust pipe and obviate your alternator.
