Old 06-19-2013, 03:10 AM   #87 (permalink)
Xist
Originally Posted by Ryland View Post
The cost is high because the steel that is being used is really tough and a carbide cutter had to be used instead of a high speed steel cutter, with that a single cutter can only make two shafts before it wears out, it also takes 3 hours to make each shaft on a CNC machine due to the splines, if the shaft was longer and there was more room to over run the cutter then it could be done differently and quicker.
What if you made the splines longer, over-ran the cutter, and then cut the spline to the proper length?
