RedDevil, for some reason this will not load your latest response. Sometimes they take a while to show up for me, which I find confusing.
My best tank is close to 60 mpg. My next tank will beat it if conditions stay the same. I got the car, so it is relevant to me. And it is cheaper than the new Prius that you do use in your...
Well, I used a Prius c... It is not a real Prius!
I did not explain why I included it. I do make an effort to keep my message length reasonable!
To me, it looked like the c was the closest thing to the original Insight once Honda told the world to do push-ups, although using Vskid3's numbers, it does not seem like the c really has an efficiency advantage over the Prius.
So, the Prius is the best, close the thread and forget about it?
