Old 06-19-2013, 10:50 PM   #27 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by hawk2100n View Post
Honda odometers could have a variability of +\- 2% which would be realistic. Not good if you are on the high side but that's just how it is. This would also be indicative of running tires smaller than stock, which I am not. They are slightly larger than stock in fact. I would love to see more civic drivers get some data on this with your tire size.
These are really interesting results. And thanks very much for them. I really appreciate the commentary on the way the GPS works. And I'd also love to have more d-series Civics test this stuff. Your last comments also raise some things I'm still curious about. (1) Do we know what the stock tire was and what its rated revs/mile was? I at least don't, and if I read the tirerack.com listings I see significantly varying revs/mile ratings for different tires in the same size category. And (2) in my experience the speedometer error tends to be higher than actual while the ODO is lower than actual. You cannot get the ODO and the speedometer to both read accurately at the same time. At least I can't. That suggests Honda designed the system to report "erroneously" for some reason, no?
Vexing.
