Originally Posted by kurzer
C102 is ground? sure?? and the fuses are ground too?
did u test the relais 1 and and the immo issue? maybe by pullig the relais?
what is the key doing, to reset the immo?
Sorry, I was incorrect earlier. The injectors are each controlled by a switched ground; I would be interrupting the common power wire going to them.
C102 is a junction/connector in the harness. There are a large number of wires going to it (at least 13 per the wiring diagram).
I haven't tested killing Relay 1...
But Vman455 did. See post 14 and 15 of this thread. Since it didn't work for him, I didn't bother trying it myself. I haven't delved into precisely how the immobilizer works, I just plan to avoid touching any wires related to it.
