Old 06-23-2013, 12:38 AM   #14 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
I have officially hit 3300 miles since installing the UG!!! I found out when the oil change alarm came on (I didn't even know it was set up)!
Anyway, 3300 miles later, I am finally calibrating it properly. Tonight I calibrated the distance. I don't have any mile markers nearby, so I had to use Google for distances, which of course, has some error built in. My trip was 4.2 miles, and I calibrated it for 4.225, just to give a little buffer. I did it 3 times, so hopefully it will work out.
I just got a fill-up today, but I forgot to hit the up button to reset it. Dratz! So at my next fill up sometime next week, I will add in the amount of fuel used (pumped) into the 'calibrate mpg/fuel' menu? Or should I wait until the fill-up after that, when I reset the UG properly?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
