Old 06-23-2013, 08:18 PM   #14 (permalink)
Grant-53
Air quick connectors are quick but not as strong as a solid connector such as a yoke and pin arrangement. If you are using air hose connectors, fill the male end with epoxy steel. The unit is much stronger in shear (right angle to the load) than relying on the unit holding together in tension. A safety strap or chain is a good addition.
