Looks like you solved your problem with the O2 sensors however if you continue to run into problems, do a search for the spark plug non fouler - O2 sensor trick. Very simple to do. They add a some standoff to the oxygen sensor by pulling it out of the exhaust flow and make the car think the cat is working. My car had the cat removed by a previous owner and that was able to get the CEL to stay off for 40k miles.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
