Old 06-25-2013, 05:41 AM   #430 (permalink)
Kenny
MetallicTurd - '94 Ford Aerostar minivan XL
90 day: 25.46 mpg (US)
That drive setup looks good, altough regarding electric drive I'd rather try some hub-motors if I were doing a similar project.
Hub motors have their advantages, but they also have significant disadvantages.
1. You need lots of torque @ low RPM. This requires large diameter motors, or gear reduction.
2. They add significant unsprung weight (copper wire & magnets) - this amount of unsprung weight seriously inhibits responsive vertical motion.
3. Complex design, because you need to stuff both the motor and the brake components within the confines of a single wheel. A compact package would also likely create blistering heat problems.
