Old 06-28-2013, 08:04 PM   #21 (permalink)
camosoul
Originally Posted by P-hack View Post
...much of my distaste for this is because it is %100 series, downsizing the engine doesn't change that...
This is true.
So if, for example, that engine were directly clutched to an appropriate sprocket and chain to a wheel, the same vehicle could cruise at like 160mpg all day vs 88.
But how does one accomplish such a task? Putting an engine to a drive system in such manner seems to negate anything else being there, thus, one is required to upsize the dino burner in order to accelerate and be useful.
Clutch in a motor in parallel, do some more maths and research bro, I'm out.
This is certainly more efficient but exists only in SolidWorks.
Something beefy enough to accel with, and then drop to dino @ 25hp for cruising. We seem to be very good at doing the opposite of that...
Now, slow speed direct-drive electric sucks much juice, but already rolling... See, backwards.
Perhaps a hydraulic drive to front wheel motors? Pop open a bypass valve like a 'clutch.' Engage once rolling? It seems to do it this way, we need to seriously re-engineer how the mechanical side works. I might imagine it, but I doubt I could ever afford it.
