Old 07-02-2013, 10:20 AM   #9 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
One wonders if you could do a sort of super-Atkinson cycle, like a 2:1 ratio instead of the 1.3:1 ratio of current modified Atkinson cycles. If you're injecting only a tiny amount of pure oxygen and a small amount of water to do the expanding, how much air you compress during the compression cycle wouldn't matter so much, would it?
Compression stroke = 40mm, expansion stroke = 89.4 (for instance).
If you're using water injection for expansion mass, that'll absorb a tremendous amount of heat. Could you do away with a radiator (and all its associated parasitic losses)?
Hmm, maybe not all. You'd probably want to reuse that water, or else have to carry around a large/heavy tank full of water. So a condenser is needed, aka a radiator. Dang it.
