Old 07-02-2013, 11:40 AM   #2 (permalink)
1carnut
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
Do you have anything to tell you if it is going into Lean Burn mode or not? I had a 94 VX and was troubleshooting a miss that it had and I know that when I unplugged the O2 sensor that the shift light did not work and obviously no Lean Burn. The shift light itself would not contribute much to a loss of mpg so it seems like it is more likely something keeping it from Lean Burn. Maybe make sure the O2 wiring is good and not touching anything?
