Originally Posted by RustyLugNut
Jeff88, what are your thoughts on this oxygen on demand?
The rest of your post is far too broken and fractured to have a proper discussion.
I'm working on a little diagram, so I will post it, because I am a visual learner more than anything.
I hope after that the fractured response to each reply will be eliminated, I was merely hoping for a response from each individual.
Originally Posted by darcane
Another concern with pure oxygen is that when mixed with gasoline it will autoignite, even at atmospheric pressures. So, if it mixes in the intake manifold, you would have a fire on your hands before it even got in the combustion chamber. Direct injection would be required.
It can greatly increases how much torque you can get out of your engine if you put in enough fuel to match.
I was working on my diagram, which already included direct injection, when I realized, 'what about auto-ignition', so I was doing a little research about it and even had the question setup in a reply so I wouldn't forget to ask about it. I guess you just beat me to it! I like the idea of auto-ignition (in the cylinder, of course), because that eliminates the need of a spark plug (and the associated items.)
More torque would mean a smaller engine would be needed, right?
