So here is a basic start to my idea. Needless to say, in no way is it anywhere near complete, nor perfected, obviously.
Here is the basic idea:
- An oxygen concentrator draws air from behind the radiator (or wherever you want)
- OC will compress the air and create a near 100% oxygen content which will be directly injected into the cylinder
- At the same time, fuel will be directly injected
- During the compression stroke, the pressure from the piston will force the oxy/gas to ignite
- Exhaust (which I think will be hotter than a standard engine) will run a turbo
- Turbo runs a generator
- Power from generator supplies battery
- Battery powers OC
Some issues:
- I doubt the turbo will be able to supply all the power to the concentrator, but hopefully it can and maybe a little bit more.
- How to "vent" the exhaust from the cylinder, other than a standard exhaust valve?
- Is water injection still necessary?
