Old 06-24-2008, 02:06 PM   #13 (permalink)
i_am_socket
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
your missing the point, that the grille has to look untouched, thus external blocks aren't allowed
Then a grill block isn't really what you're looking for as that is the point of a grill block: to block the grill. Blocking behind the grill will likely give you an increase rate of engine heating which is a good thing, but that's a mechanical benefit and not so much an aerodynamic one.
To achieve the [external] aerodynamic benefit of a grill block and still have the grill visible, look into see-through materials like cheap plastic picture frames and whatnot that you can attach via zip ties or double sided tape.
