Old 06-24-2008, 12:27 PM   #11 (permalink)
Hello,
I think it would help if you put flush covers on the openings that are already blocked. Recesses are bad...
Old 06-24-2008, 12:42 PM   #12 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
Hello,
your missing the point, that the grille has to look untouched, thus external blocks aren't allowed
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 06-24-2008, 02:06 PM   #13 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Then a grill block isn't really what you're looking for as that is the point of a grill block: to block the grill. Blocking behind the grill will likely give you an increase rate of engine heating which is a good thing, but that's a mechanical benefit and not so much an aerodynamic one.
To achieve the [external] aerodynamic benefit of a grill block and still have the grill visible, look into see-through materials like cheap plastic picture frames and whatnot that you can attach via zip ties or double sided tape.
Old 06-24-2008, 03:43 PM   #14 (permalink)
Loving my blueberry
cwarnar's Avatar
Altimax - '98 Nissan Altima GXE
90 day: 32.88 mpg (US)
The Wan - '07 Toyota Sienna CE
90 day: 22.81 mpg (US)
Got my more permanent upper and lower blocks done this weekend. The paint isn't quite a match but I am already noticing an increase in mileage... I have almost 450km on my tank and my gas gauge is only at 1/2 tank. I am expecting a 2-4 mpg rise based on the 80-90% of highway driving I do.
Old 06-24-2008, 03:53 PM   #15 (permalink)
Hello,
I'm not sure it's always that simple. An egg crate grill, at a large angle to the incoming air, ought to be about the same drag whether it's blocked on the front or rear surface. A stagnation bubble will form in front of it and the drag would be more pressure related instead of friction.
Old 06-24-2008, 07:12 PM   #16 (permalink)
POS - '97 Ford Aspire
90 day: 47 mpg (US)
[QUOTE=i_am_socket;37889] Blocking behind the grill will likely give you an increase rate of engine heating which is a good thing, but that's a mechanical benefit and not so much an aerodynamic one.
QUOTE]
blocking the radiater will not give you an increased heating rate!!! the water does not leave the engine untill it's HOT (unless you dont' have a thermostat, and if thats the case, you are asking for problems).
Old 06-24-2008, 07:13 PM   #17 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
i have a large external grill block on Jeep 2, i have noticed a decent increase but i cannot give numbers at the moment because i added it 90 miles into the last tank, and will not finnish off the tank i am on for another 3-4 weeks. anyhow, observations on my end, i tow other vehicles quite frequently, 3 cars in the last two weeks, and have had no overheating, i drive mainly in the city and a grill block is most functional on the highway.
if you wanted the grill to be visible you could always use a piece of plexi glass, it doesnt have to be thick but i definately understand not wanting it to be visible so i wont nock on you for putting it behind.
anyhow, remember, every little bit helps and grill blocks are cheap so even if you only get 1 mpg increase you still come out a little farther ahead.
Old 06-24-2008, 08:59 PM   #18 (permalink)
EP3
EP3's Avatar
02WhiteEp3 - '02 Honda Civic Si
90 day: 28.35 mpg (US)
Send a message via AIM to EP3
Malibu I hear you. I want the reward with out the look of. Just something simple. I want to design something that will just look sleek. I might just take the bumper off and fill in my honeycomb design and grind smooth and spray black. Here are some picture. For the bottom I have not decided yet.
"There is no such thing as a dumb question.. Just dumb people".
Old 06-24-2008, 09:01 PM   #19 (permalink)
EP3
EP3's Avatar
Also I plan to delete the big H
Old 06-24-2008, 09:43 PM   #20 (permalink)
FumeSniffer
cookie96civic's Avatar
FumeSniffer - '96 Honda Civic DX
90 day: 46.19 mpg (US)
Big Gulp - '06 International 8600-375 Twin Turbo
90 day: 7.15 mpg (US)
I have a 96 civic, small upper grill and large lower intake, at speeds over 45 is there enough air to cool the engine if I block both?
DIY Vibe Grille / Fog Deletes trikkonceptz DIY / How-to 20 04-27-2011 03:27 PM
How does a grille block improve warmup time? fanamingo EcoModding Central 30 05-03-2010 06:13 PM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-31-2010 12:21 AM
Hybrid Grille Block/ HGB Hybrid Effects Aerodynamics 0 03-22-2008 09:53 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 11:14 AM
