Old 07-02-2013, 10:29 PM   #1 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Analyzing Gen1 Insight Acceleration to 30 MPH
There was a post here at EM, where a member was asking for help regarding lugging the engine, and resultant fuel economy.
I responded to the thread, but my response got me thinking about a better way to analyze my reported gas mileage findings.
The analysis at this point is quite limited, and probably will not get much better, as part of the gas measurements and resultant calculations, are based on several factors that are hard to measure without dedicated equipment.
The first graphic below shows a page from a spreadsheet that discusses my field measurements and close approximations to distance traveled during those measurements. The distances are estimates because the car dash display only starts to indicate travel every 0.1 mile, and several of my acceleration tests occurred over a shorter interval than the display can reveal. Therefore there is *uncertainty* in my measurements, and these will be discussed below.
Three acceleration mileage tests were performed:
A) Accelerate from 15 to 30 mph in second gear only, TPS of 70.
B) Accelerate from 15 in second to 18, shift to third and accelerate to 26, shift to fourth and accelerate to 30 at TPS of 70.
C) Accelerate from 15 in second, to 18, shift to third and accelerate to 26, shift to fourth and accelerate to 30 at TPS of 30.
I will discuss some of the important assumptions:
Item 6: These distances are my best estimate on distance to 30 mph. The three graphics show that being off slightly shifts the best efficiency from Option A to B or C.
Item 7: Calculated total gas usage in CC's based on estimated distance from Item 6.
Item 14: Is the total distance needed to travel to get the equivalent gas consumption of 100 mpg, after initial acceleration.
If the real moving distance to 30 mph is only 0.4 mile then accelerating to 30 mph with Option A is better.
On the other hand, if the real moving distance to 30 mph is actually 0.6 miles, then Option B or C is better.
My personal favorite is Option B, because the throttle plate open for low pumping losses, and the RPM's low for low piston friction. But is this really the best of the three options?
You can clearly see that determining the best way to accelerate a Honda Insight from 15 to 30 mph takes more than just seat of the pants gas mileage measurement. Dedicated equipment would go a long way to determining true gas consumption and distances traveled.
P.S.
After documenting my findings in this thread, it *finally* occurred to me that accelerating to a higher speed will accomplish two things:
a) cause more gas consumption over the total acceleration, making it easier to get a solid measurement.
b) because of the higher speed, get a more accurate distance measurement.
Jim.
ID:	13375   Click image for larger version
ID:	13376   Click image for larger version
The Following 3 Users Say Thank You to 3-Wheeler For This Useful Post:
mikeyjd (07-12-2013), niky (07-03-2013), some_other_dave (07-02-2013)
