Your setup works just fine. You do'nt need to select injector type.
Adjust the "Injector delay" in the menu. Try adjusting it up or down until the instant consumption is realistic.
If your inj delay is too big, then it loses data (=accelerations), and if too small, it goes nuts.
And every up-to-date MPGuino supports P&H injectors as far as i know.
