Old 07-02-2013, 05:17 PM   #1 (permalink)
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
illegitimate fuel consumption
Hello,
i install the MPGuino yesterday. It seems that all worked, but...
When i acellerate the fuelconsumption doesnt increased
The consuption raised only in lower gears..
What i do wrong?
Old 07-02-2013, 06:00 PM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
What is your fuel injector input wire connected to?
Old 07-02-2013, 06:10 PM   #3 (permalink)
Jack-Lee's Avatar
I tested both: The + and - Wire to the injector
+wire : nothing to see on the display
-wire : works, but not correct.
When i accelerate, the value is not change at all.
I think the injector is a "Peak and Hold" type.. ?
Old 07-02-2013, 07:33 PM   #4 (permalink)
MPGuino Supporter
t vago's Avatar
It may be possible. Can you tell me what the coil resistance is, of your fuel injector?
Old 07-03-2013, 04:44 AM   #5 (permalink)
Jack-Lee's Avatar
Hello,
the resistence : 1.3Ohm
Its a Singleinjector
The Injectors from the stronger MPI Motor : 15,9Ohm
Old 07-03-2013, 08:23 AM   #6 (permalink)
MPGuino Supporter
t vago's Avatar
Hello,
This injector is very likely a peak-and-hold injector. They have not yet figured out how to get an MPGuino to work with these, I'm afraid.
That injector is very likely a normal injector.
Old 07-03-2013, 10:40 AM   #7 (permalink)
Jack-Lee's Avatar
Hello,
good.. i had two MPGuino. One from MTH and one vom "Wiseman".
The Guino from Wiseman should work with this "peak and hold" Injectors!
Fine
Old 07-04-2013, 07:24 AM   #8 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Your setup works just fine. You do'nt need to select injector type.
Adjust the "Injector delay" in the menu. Try adjusting it up or down until the instant consumption is realistic.
If your inj delay is too big, then it loses data (=accelerations), and if too small, it goes nuts.
And every up-to-date MPGuino supports P&H injectors as far as i know.
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 07-04-2013, 08:56 AM   #9 (permalink)
Jack-Lee's Avatar
Hi,
the consumption dont change when i accelerate...
And it is a peak and hold injector
I try it with the MPGuino from Wiseman (he has impliment the software solution from the Guino-Wiki)
Old 07-04-2013, 12:31 PM   #10 (permalink)
MPGuino Supporter
t vago's Avatar
You sure about that? The MPGuino wiki still has an advisory that states that peak-and-hold injectors are not yet supported.
