Old 07-05-2013, 06:01 PM   #80 (permalink)
GreenHornet
GreenHornet's Avatar
Today I was beginning to figure out my shift points and rpm for optimum fuel efficiency as well as determining just how fast I can theoretically go with the little 2 cylinder unmodified in stock condition with my current proposed gearing.
So the Top speed is roughly 80mph estimated and that is granted I can hit my weight of roughly 1,200lbs and hit my drag coefficient of .18. This would require 9.12 HP to overcome air drag. Rolling resistance is 3.33
For a total of 12.45 HP to run 80 MPH. Factor in another 10% loss for good measure and you have 13.695HP. If I can obtain an even lower coefficient of drag say .14 then we are up over 85mph from a stock 2 cylinder .5L diesel
Proper gearing for these little small diesels can not be over looked. One must remember these little diesels like to be worked hard. The high output guys who run at 3,600rpm stock can max out at 3,800rpm unmodified. Tractor pullers have gotten them upwards of 6000rpm heavily modified. The trick is to run them in there sweet spot. So what is there sweet spot and how the heck do you begin to figure it out?
So what you need is the Performance data this will give you the BSFC or brake specific fuel consumption data along with the Torque curve and KW output all at a given RPM. This will clearly show you where the engine likes to be at for lowest fuel consumption and best range of torque.
The 2 cylinder Yanmar for example uses the least amount of fuel right at 1800rpm and puts out just under peek torque at this point in its rpm range. 1800rpm is only about half load or 50% of max 3600rpm. So when people say these little diesels like to run hard this can be misleading. You will think that you need to run it upwards of 3000rpm and this is simply not the case. The argument is that running it at higher rpm extends the life of the engine because engine gunk does not build up. While this may be true engine build up will not form at all at any engine load if you utilize a water/meth injection system effectively
Now 3600 rpm is not max rpm it is the nominal operating rpm. Max rpm is actually 3800 roughly stock so 1800rpm is actually 47.5% load. Now knowing that fuel consumed is proportional to power developed we need to know how much horsepower is used at 1800rpm. This figure will be in KW and we will also need to know the g/KWH usage which will be for the Yanmar around 256g.
Convert your 5.5kw to horsepower = 6.7hp
set up equation
6.7hp X .47.5% load X 256g = 0.814L = .21 gallons per hour
This figure is consistent with what we would see out of a diesel genset. As you can see if we can set up our shift points to stay around this 1800rpm range fuel economy will be extremely frugal. You could run 5 hours before going through 1 gallon of gas without any special driving techniques or any special engine mods.
Now at 6.7Hp what kind of mph range can we achieve?
60 MPH takes 3.85 HP to overcome air drag.
Rolling resistance is 2.50
For a total of 6.45 HP to run 60 MPH
My inputs for this estimate were:
Calculate HP For A Given Speed
Coefficient of Drag = .18
Frontal Area of Car = 14.9 Sq/Ft
Weight of Car = 1,200 Lbs
Velocity of Car = 60mph MPH
Link to calculator = Calculate HP For Speed
Now that we know we can go 60mph using only 6.45hp we can set up our gearing to take full advantage of this
Now if we look at our Yanmar 2TNV70 performance Data we can see that at roughly 1,750rpm all the way to 2,400rpm the fuel consumption stays right around 260g. This is what they refer to as the sweet spot! This gives us a nice window of opportunity to keep fuel consumption relatively low yet take full advantage of engine torque! If you notice even at 2,400rpm we are still very close to peak torque output for the tiny engine.
So during normal driving we want to keep the engine under 2400rpm at all costs essentially.
Fuel consumption for comparison sake at 2400rpm is:
10hp X .63% X 260g = 1.6L = .42gph
This power usage still puts us easily over 100mpg!
tire diameter used = 22.4 Smart car stock wheels with stock continental tires.
transmission gear = .63 (OD) 5th gear of T5 transmission
Rear gear differential = 3.27 stock GT6 differential
Engine Speed (RPM)
5000 RPM 161.74 MPH
4500 RPM 145.57 MPH
4000 RPM 129.39 MPH
3500 RPM 113.22 MPH
3000 RPM 97.04 MPH
2500 RPM 80.87 MPH
2000 RPM 64.70 MPH
1500 RPM 48.52 MPH
1000 RPM 32.35 MPH
Now you can see that at 2,500rpm we are at roughly 80.87mph and if you recall that our Yanmar has just enough HP to get us to the 80mph mark! With the right gearing we can achieve this at only 2,500rpm still way under max engine load. So anything under 80mph is going to give us exceptional fuel economy with the T5 gearing and Yanmar 2 cylinder engine
What I found interesting was just how much going from using 6.7hp to 10hp affected our fuel consumption from .21gph to .42gph
Moral of the story here is if you want incredible fuel economy you need to get all the pieces right. You not only need correct gearing, low curb weight, solid aerodynamics but most importantly you need to know and understand your engines BSFC and how to use it to your advantage!
Now just think what someone trained in eco driving techniques could do with the Tigon diesel only not to mention a fully hybridized model of Tigon. Fuel consumption would not even be on the charts
Name:	Yanmar 2TNV70-ASA #1.jpg
ID:	13384   Click image for larger version
Name:	Yanmar 2TNV70-ASA #2.jpg
