Originally Posted by mikeyjd
when are you gonna start posting fuel logs?
Well ...
That's a wee bit of a problem
The Garage software doesn't allow for kilograms of CNG.
There are 2 very different gas qualities, H-gas has some 17% more energy in it than L-Gas.
In the US, you probably have different caloric values again, and pounds instead of kg.
That'd probably make it a bit too involved to get this into the Garage software ...
I've been looking for a way to convert kilograms and caloric value to kWh, which is in the Garage, but it ain't that easy without knowing the (variable) density.
I could use an average value, but it wouldn't be correct.
Easiest solution :
I'll put my spritmonitor fuel log in my signature.
[this will be changed to display miles / kg when spritmonitor.de get the conversion properly sorted
