Old 07-08-2013, 05:29 PM   #59 (permalink)
jackbauer
jackbauer's Avatar
So I had a busy weekend with the yacht. Got the controller mounted above the motor and a 10mm ali plate installed in front of the motor to carry contactors , fuses etc. Now if i can just figure out how to crimp those ampseal pins without a $500 tool .....
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
