05-14-2013, 03:39 AM
#51 (permalink)
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed 90 day: 34.62 mpg (US)
Thanks for the latest vid, Jack. What's the name of those rivet nuts you were working with? I can think of like 10k possible uses for those...  I expect that mcmaster.com carries them.
Btw, I haven't read all of you posts, but I'm curious, are you using new batteries, or did you scavenge yours from somewhere? Are you going to use regen?
05-14-2013, 06:01 AM
#52 (permalink)
VFAQman
https://www.google.com/search?q=nuts...hrome&ie=UTF-8
05-19-2013, 03:57 AM
#53 (permalink)
Yeh the nutserts (also called rivnuts and a few other names) are very useful. Only just discovered them really. I'll be using the new CALB CA180FI cells in this car.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
06-19-2013, 05:29 PM
#54 (permalink)
Maiden voyage gets closer! Controller is nearly done. Just gotta see if my inductor bank can take 1000A
www.evbmw.com
06-20-2013, 12:13 PM
#55 (permalink)
Very nice!
07-03-2013, 09:37 PM
#56 (permalink)
ps , what voltage (rail) are you using for your POT. 3v, 5v or 12v, ?
5v. , that is what i used, and over 7v damages the chip.
and over 5v is max A/D conversion, rate, at 1023 counts
07-04-2013, 04:18 PM
#57 (permalink)
Trial fitted the controller this evening. It fits
@jtgh using 5v for the pot.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
07-04-2013, 07:56 PM
#58 (permalink)
Well I'll probably wet my pants while waiting impatiently for test drive news  Meantime I'd like to ask you one of those "frequently asked questions"; is 16 ohm the final value for both turn on and turn off gate resistance?
Also, regarding the arrangement of KiloVac contactors - aren't they supposed to be oriented in one way, i.e. current flows in direction A1-->A2? (datasheet says A1=positive, A2=negative).
Mike
07-08-2013, 05:29 PM
#59 (permalink)
So I had a busy weekend with the yacht. Got the controller mounted above the motor and a 10mm ali plate installed in front of the motor to carry contactors , fuses etc. Now if i can just figure out how to crimp those ampseal pins without a $500 tool .....
www.evbmw.com
07-08-2013, 05:33 PM
#60 (permalink)
Just a quick pic of the installed controller. Anyone wanna make me some "Re-Moc" stickers ??
www.evbmw.com
