Originally Posted by brucepick
Warning: This is a "woe is me" story. I'm really pleased with how well Team Honda is doing, and with all the good stuff in this thread - which I started a year ago tomorrow.
Back in Feb-March 2011, at about 219K miles, I had a shop refurbish the head. It had one badly burned valve plus others also needed replacement. A friend pulled the head and reinstalled it for me. Following that I did some nice mods - a belly pan, and I disabled the alternator, replacing it with enough batteries to run for hours. Plus some other stuff. Late last summer she was getting 54-55 mpg and I was pleased.
The car is now at about 285 K miles, and losing coolant, it looks like its going out via the head gasket and cylinders. And I'm getting a P0302 code, misfire on cyl. #2. That spark plug was oil covered when examined. So I suspect that again, a valve seal or guide has failed, and the dripping oil has again burned the valve.
Bugger.
Some of these symptoms sound the same as what I'm seeing on my HX. I'm smelling a whiff of smoke on startup and occasionally getting a miss trouble code (multiple cylinders though) shortly after starting it when it's cold. I'm guessing it is a bad valve seal.
Or maybe a plugged EGR? (<---wishful thinking?)
