Originally Posted by HypermilerAX
Does that take into account BSFC variations? If yes, how?
using a bsfc semiempirical mathematical model with 20 parameters and variables.
and the fuel consumption has the main variables and parameters in use in a code of some hundreds lines, i have not counted them, i'm sorry.
Attached you will find a graph comparing the fuel consumption between standard Lupo 3L and the estimation of what is happening on the Lupo 2L project and also the efficiency from 0 to 1 (i'm not using g/KWh because US and UK use other units that i found difficult to understand because i'm not used to them, and i want keep it simple for everybody.
