Old 07-08-2013, 05:23 PM   #301 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Congrats - great job! Lupo rules !
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 07-08-2013, 05:51 PM   #302 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Pretty neat !
That's 57g CO2/km.
You'd qualify for exemption of the London Congestion Charge
The Following User Says Thank You to euromodder For This Useful Post:
Vekke (07-09-2013)
Old 07-09-2013, 03:42 AM   #303 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Here is the video which is pretty long...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 07-09-2013, 05:45 AM   #304 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
Doesn't increasing the power of the engine increases consumption, the load of the engine being lower?
With your data, I calculated that your engine has 29% efficiency (289,9 g/kWh) during your record. To make 2 l/100 km at 100 km/h you need 34,66% efficiency.
On a stock Lupo, the best efficiency at stabilized speed and on the flat is achieved in 5th gear at 150 km/h. At that speed, the car burns 5,52 l/100 km (SSP_218) which makes 33,56% efficiency (250,5 g/kWh). And the engine turns at 3158 rpm which means that better efficiency can be achieved at lower rpm (1500-1750?) and equal load which means... custom bigger gearing (like 60 km/h at 1000 rpm or even more). What is your engine load at 100 km/h?
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
Old 07-09-2013, 07:45 AM   #305 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
I'm guessing (predicting witrh a fuel consumtpion model) that your cars fuel consumption is:
speed (km/h) f.c (L/100km)
65 1.63
73 1.78
80 1.91
90 2.10
93 2.15
95 2.21
100 2.32
120 2.90
130 3.14
160 4.17
But because the winners car is running on E85 (i quess in a petrol engine) you must multiply your fuel consumtion figures by a factor higher than 1.15 (ratio of energy between diesel and gaoline) but E85 has 33% less energy per liter than gasoline so aprox. 1.5 or so because E85 has less energy per mass than diesel, but also because the engine i'm sure it has lower efficiency than your car's engine in spite of your low load). ITs a total factor of about 1.74 only with the energy content in fuel.
Edison2 - Welcome claims a mass of 450 kg and a cd of 0.15.
2 L of diesel /100kms aprox 3.48 E85 L/100km, if i'm not wrong.
Sold:
Old 07-09-2013, 09:17 AM   #306 (permalink)
AX - '95 Citröen AX
Does that take into account BSFC variations? If yes, how?
Old 07-09-2013, 10:36 AM   #307 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Very nice work!!! Love that car!!!
Old 07-09-2013, 01:36 PM   #308 (permalink)
using a bsfc semiempirical mathematical model with 20 parameters and variables.
and the fuel consumption has the main variables and parameters in use in a code of some hundreds lines, i have not counted them, i'm sorry.
Attached you will find a graph comparing the fuel consumption between standard Lupo 3L and the estimation of what is happening on the Lupo 2L project and also the efficiency from 0 to 1 (i'm not using g/KWh because US and UK use other units that i found difficult to understand because i'm not used to them, and i want keep it simple for everybody.
Name:	lupo3l efi and f.c..png
Sold:
The Following User Says Thank You to ausias For This Useful Post:
Vekke (07-09-2013)
Old 07-21-2013, 08:42 AM   #309 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Secondary objective completed:
Old 07-21-2013, 09:21 AM   #310 (permalink)
AX - '95 Citröen AX
Wow. My AX needs 36 seconds for 80-120 in 5th gear.
audi a2 3l 1.2 tdi, tuneko, vw lupo 3l.
