Old 06-24-2008, 07:12 PM   #16 (permalink)
rocket
POS - '97 Ford Aspire
90 day: 47 mpg (US)
[QUOTE=i_am_socket;37889] Blocking behind the grill will likely give you an increase rate of engine heating which is a good thing, but that's a mechanical benefit and not so much an aerodynamic one.
QUOTE]
blocking the radiater will not give you an increased heating rate!!! the water does not leave the engine untill it's HOT (unless you dont' have a thermostat, and if thats the case, you are asking for problems).
