Old 07-09-2013, 06:54 PM   #17 (permalink)
oil pan 4
You could also put a smaller radiator up front to give you that gap you need between the radiator and body by putting in a smaller radiator. Then you could do a remote mount radiator using a heater core or motor cycle radiator some where and split coolant flow off to it.
Or do what I did, cut away the body.
From this:
To this:
I did this to expose more of the radiator to air flow. If I did not have the large diesel radiator there would be no radiator behind what I cut away.
The next day I welded up a nice solid 1'' angle iron reinforcement to go around the new opening I created.
Then I installed grill shutters just for good measure:
http://ecomodder.com/forum/showthrea...tml#post379284
From your pics it looks like relocating the battery or washer fluid bottle would be easier.
Feeding the engine hot under hood air through an uncooled supercharger sounds like a bad idea.
ID:	13423   Click image for larger version
