Originally Posted by GreenHornet
Now 3600 rpm is not max rpm it is the nominal operating rpm. Max rpm is actually 3800 roughly stock so 1800rpm is actually 47.5% load. Now knowing that fuel consumed is proportional to power developed we need to know how much horsepower is used at 1800rpm. This figure will be in KW and we will also need to know the g/KWH usage which will be for the Yanmar around 256g.
I notice that your specified engine is described by Yanmar as a fixed-speed model. Will it function well in a variable speed mission like a car? You might be better served by the related
2TNV70-ASA
Some of your math looks strange, I think you might be considering variables that shouldn't be considered.
