Originally Posted by modproductions
Hi,
wow you have done a lot of work on this car.
If you want to modify it, I suggest you to make it narrower at the back. It will be better with side wind.
Forgot to raise this question. I read that taper beyond 200mm from both sides is the most you can go. And if you make too much taper the flow will start to separate sooner. The same goes if you round the rear corners.
