Old 07-15-2013, 02:04 PM   #3 (permalink)
lordherald
daewoo - '99 Daewoo Lanos SX
90 day: 39.27 mpg (US)
Update on stupidity
I started the car this morning to head into school and it started to miss.
The comp in the car was trying to use the newly repaired sensor to adjust the engine and because it was out of range kept making constant adjustments to the fuel mixture.
I checked a number of things and eventually just cut and taped my new wiring job to the sensor and then it started to run correctly again.
I guess I will continue looking for a different head for the car and hopefully wont botch it up as bad the second time.
The car does need a "new" head since the previous owner stripped a plug, had it sleeved, and then never changed the plug until it became one with the sleeve.
Just trying to save a little more money!
