I changed out the camshaft sensor on my Daewoo today.
It was a pretty quick job, much faster then I had planned.
Once I had finished I turned on the car with my code reader attached and cleared out the 342 that has been keeping the CEL on for months.
I started the car and within about fifteen seconds the light comes on again.
I check every thing over clear the code and try again.
This time I get two codes, things are looking up or down, depends on how you look at it.
I then spent another hour checking voltages and making sure of where the problem is.
I found that the plug between the main harness and the senors harness has a questionable connection. I am getting the 5v i need on one side of the plug and 2.74 on the other. I think yay I found it.
I jumper past the plug and still the light comes on.
So i change to a smaller gauge wire to more closely match the original.
Still the light comes on.
I redo a previous set of solder joints and make all three wires match the stock size.
It takes longer to set off the code.
I think I am making progress.
Then the truth dawns on me the head in my car is a 1998 and it didn't have a cam sensor. There isn't anything on the cam gear to break the field of the sensor. So I wasted about four hours installing a $20 part that wont do anything.
