Per the 100+ hypermiling techniques sticky, there is a "braking hierarchy":
BRAKE TIPS
44) The most efficient way to slow down
When you *have* to slow down, here's an approximate heirarchy of methods, from best to worst.
1) coasting in neutral, engine off (ie. roll to a stop);
2) coasting in neutral, engine idling;
3) regenerative coasting (hybrid vehicles)
4) regenerative braking (hybrid vehicles)
5) coasting in "deceleration fuel cut-off" mode (in gear, above a certain engine RPM)
6) conventional friction braking (non-hybrid or hybrid)
Choosing the right method depends on traffic conditions (following vehicles) and how quickly you need to stop.
45) Conserve momentum: avoid stopping
Avoid coming to a complete stop whenever possible (and when safe and legal of course). It takes much less energy to accelerate a vehicle when it's already traveling just a few kilometers per hour than it does from a complete stop.
47) "Drive without brakes" (DWB)
Minimize use of the brake pedal. Each time you press it, you're effectively converting gasoline into brake dust and heat.
Driving as if you have no brakes will cause you to do two things: 1) reduces 'excessive' acceleration, and, 2) extends the amount of time you spend coasting down to stops and turns.
Obviously you have to balance use of this technique against traffic conditions so as not to adversely affect other drivers.
See the Ecomodder Blog for more information on DWB.
Therefore, in your situation, it all really depends on timing. Ultimately, the goal is to conserve momentum and to avoid coming to a complete stop.
If you have the room to coast to a stop at the stopsign, then use methods 1 or 2.
If you're going too fast and need to scrub off some speed...but still able to coast thru the light...then use method 5.
