Originally Posted by idtent
Maybe I'm just too hot headed but I was just wondering if anyone read my post or was the info irrelevant
The info was not irrelevant. I might be testing a smacks booster cell to see how it performs. It is hard to show that it is working especially to more skeptical people when you only give a little description and no hard numbers like trip miles and gallons for your run. As far as the other stuff like Meyers, unless someone from that crowd can replicate it, prove the claims, and give away/sell the plans, it doesn't matter because its not accessible anymore. I need something that will work now. If a better process emerges then great, that can be adapted. If you build another one then use KOH or NaOH not lye. Document everything you do, your results, and post it then.
