Old 07-18-2013, 01:31 AM   #16 (permalink)
retepsnikrep
I suggest you read the post before yours and then the threads over at insight central. Yes it is available. It might stop an IMA related check engine light as long as it does not come on as soon as you turn on the car.
Have you found out what the error code is on your car? If not then you are just gambling on landing on the correct answer.
