Old 07-18-2013, 02:48 AM   #1 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Decoding & Breaking Down the 1ZZ-FE Engine BSFC
Can somebody help me with the BSFC map for my 2001 Toyota Corolla?
Do I have this right?:
The best BSFC engine speed is around 3100-3200 RPMs. The engine puts out the most torque around 4500 RPMs. The top chart shows the least power at 1000 RPM and the most at around 5500, tapering off after that. Is that power (in kW) the engine uses or the power it outputs?
At 60, the engine speed is around 2000-2100 RPMs, but the best (least) pollution is at 3100-3200. Is there any way to make the 'g/kWh' the least at a lower RPM?
Thanks for the help! I'm hoping with this information, I can *properly* drive the car!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
