So we're ditching the genset option because the Leaf's max charge rate is not high enough?
It does not have to charge the battery, right? It just can feed the EV's engine directly.
We accept that converting a car to an ICE pusher trailer with all the controls is feasible.
Circumventing the max 'charge' limitation to match the power used under load should not be harder that that imho. With twice the power generated the problem disappears.
Then the range is limited only by the generator's tank size.
