Presumably, the tires would be held constant for the purposes of the test. Load rating (# of plys) would vary the weight of identically sized tires.
Mass concentrated towards the outside of the rotating object matters more than mass closer to the axis of rotation.
But rotational energy is a give and take situation, while deviations from a direct path are just take, take, take. Every time you hit a pot-hole, the weight of that corner is lifted by a punch from the sprung mass. Wheel alignment/steering play—same thing.
Where does that energy come from, out of your gas tank?
