Late and/or early intake valve closure has been used before for efficiency improvement. It's typically called Miller cycling or Atkitson cycling (depending on who you ask). The Toyota Prius engine uses this. The effect is an expansion ratio which is greater than the compression ratio. What you're suggesting wouldn't change the effective compression ratio and I'm not sure as how it would reduce pumping losses. Remeber that lower cylinder pressure on the intake stroke is going to increase pumping losses.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
