Old 07-21-2013, 04:24 AM   #269 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Originally Posted by IamIan View Post
mpg is a very poor efficiency metric.
1 mile is not a set amount of joules ... but 1 gallon is.
You could be at the same % efficiency and at very different MPG , as the energy use per mile changes... heck your efficiency could be higher and have a lower MPG.
Honestly, I have no idea what you are trying to say here. A Joule is a measure of energy. A kWH is a measure of energy. A gallon of fuel contains a known measure of energy (135.74MJ/gallon for diesel fuel, according to Diesel fuel - Wikipedia, the free encyclopedia) and therefore could be considered to be a reasonable proxy for a measure of energy. Regardless of the measure of energy we are using, we are talking about trying to travel some distance per hour; 65 miles in the examples I've used. Some amount of energy is going to be consumed in those 65 miles in order to cover them. If you want to convert the gallons of fuel to Joules and call it miles per Joules, or convert it to kWH and call it miles per kWH makes no difference. Miles per gallon works quite well because in both the case of the generator and the pusher, that's what you are starting with... gallons of fuel put into the tank of either option. If you can come up with a better measure of energy used over distance, please do and explain why that is better than MPG.
Asking for a link to a off the shelf generator ...that you want to compare to the custom eco-modified pusher ... is not a apples to apples comparison.
If you wanted apples to apples ... the pusher would have to be just as off the shelf available as the generator ... and if you did that ... the generator will win the availability by a long margin.
If you instead go back to the back Eco-Modded Generator vs Eco-Modded Trailer ... that both use off the shelf components type of Apples to Apples ... that is back to the example already at hand ... and it results in areas weather either one is better depending on the situation ... in some situations the pusher is more efficient and in other situations the generator is more efficient.
There is no entirely off-the-shelf solution for either option. In the case of the generator, you will need to customize the EV to 1) allow charging while driving, and/or 2) provide a higher capacity built-in charger if you want the genset to offset the EV's consumption, and/or 3) customize the entire BEV system in order to direct-drive the motors while also charging the batteries in order to keep the generator's load constant. In the case of the pusher, all the customization is constrained to the pusher itself with the exception of the hitch on the EV (this obviously applies to the generator option too) and maybe the control wiring for the pusher (though that can just as easily be portable).
#1> less peak efficient ... yes ... other than that ... it depends on the situation... There are many points on the BSFC that have been shown would be more efficient via the generator.
#2> No ... It doesn't have the same BSFC issues the pusher has.
The generator can run at any peak efficiency RPM it wants to , no matter what the vehicle speed is ... the pusher can't do that ... transmissions have limits ... the generator can run at any peak efficiency torque load it wants to , no matter what the torque load at the tire is ... the pusher can't do that... again transmission have limits... and the generator can run at any peak efficiency combined RPM and Toque and Power it wants to ... the pusher can't do that ... again transmissions have limits... the cycle through the batteries while lower ... is still more efficient than some of the pusher BSFC operating conditions ... which gives another functional difference.
They are not the same.
Thus the areas of on the BSFC I color coded... there are situations where the pusher is more efficient than a generator ... and there are situations where it is less efficient than a generator.
Here, I'm not clear if we're talking about the same thing. You're saying that the generator can run at peak efficiency more often than the pusher can run at peak efficiency, right? To me that doesn't mean anything because the peak efficiency of a generator may not be as good as the peak efficiency of a pusher... that is, the generator BSFC != pusher BSFC. To me, the more efficient solution is the one that gets me farther on a gallon of diesel, and as I've shown, the diesel generators which can keep up with the EV's energy consumption at 65mph will get me only a fraction of the distance on a gallon of gasoline compared to the pusher.
Even if we where to assume that the exact same diesel engine, the VW TDI engine, is being used for the pusher as for the generator, I really do not know that the TDI has enough horsepower to run a 20+ kW electric generator, or that the TDI's peak efficiency RPM aligns with the electric generator's peak output rpm. For example, a 2-pole generator must run at 3600RPM to output 60Hz; a 4-pole generator must run at 1800RPM to output 60Hz. Neither of those RPMs fall in the TDI's peak efficiency spot on the BSFC chart.
We also have to be talking about the same range extending capabilities for the generator as the pusher... That is, the pusher allows unlimited range without extended stopping provided the driver can fill up the tank with more fuel. In order to compare apples to apples, the generator then also has to provide that same capability... otherwise we'll start going off into la-la land where we could also downsize the pusher to only provide a fraction of the total cruising hp required to maintain our goal of 65mph... etc.
Therefore, the generator must replenish the energy consumed by the EV, Joule for Joule, in which case we are talking about a 20kW generator if used with a middle-of-the-road (from EV efficiency point of view) Leaf, right? In which case:
  1. As noted, even at peak efficiency, constant load, a typical off-the-shelf 20kW will consume more gph than the TDI pusher running at 65mph... In this situation, the genset looses. If you change the parameters of our situation (travel unlimited miles at 45mph instead of 65mph), you may be able to downsize the genset but at the same time the pusher will get even better fuel economy... so even in the situation of changing parameters, the genset looses.
  2. If you hook the genset directly to the motors (without the super-fancy customization mentioned by jamesqf) in order to bypass the battery charging losses, your genset load will vary (e.g. constant RPM, but varying torque) as the electric motor's load varies... yes, that's effectively a direct genset to wheels connection, and the genset will not be at it's peak efficiency all the time. Plus you'll need to up-size the genset in order to accommodate the times that the power draw is greater than the draw during cruising. In this situation, the genset looses.
  3. If you manage to do the full customization proposed by jamesqf where the genset powers the electric motors and charges the battery in such a way that the genset is under constant load all the time, then you're effectively back to a very complex form of #1... the genset must be sized large enough that the EV's consumption is offset and the battery isn't drained regardless of route. So we're still talking about a genset that is around 20kW, which we've already established consumes more than the pusher per mile traveled.
AFAIK , I already listed that.
I did not include any specific vehicle ... because it doesn't matter ... 1 joule of mechanical energy to move vehicle A will move vehicle A the same no matter what it's source is ... 1 joule is 1 joule.
All I saw is that you pointed to a BSFC chart for a TDI... Not a BSFC chart for a generator (one which can compensate for the power consumed by the EV), and not a comparison of BSFC between the TDI and the generator. Generally, you can't run a generator at any RPM you choose; you have to run it at a specific RPM to get the specific AC frequency which means that the BSFC chart for an automotive engine is likely invalid for a generator engine. As well, just looking at the BSFC chart does not tell the whole story... in order to get the whole story of how the gallon of fuel that you put into the generator (the energy input) gets converted to some distance traveled at 65mph (the energy output), you must include the vehicle... because that absolutely does matter. It's the same with the pusher... that same gallon of fuel will generate some amount of power, and how efficiently that power gets converted to some distance traveled at 65mph is entirely dependent on the rest of the system (transmission, final drive, tires, etc); ignoring the rest of the system makes the knowledge of how much power the pusher engine creates entirely useless information.
On the other hand, I looked at how far each solution can take me on a gallon of fuel, and found no situation where a generator will take me further than a pusher... even assuming no efficiency-related modifications on the pusher and genset-specific modifications to the EV (such as modifying the charger to accept a 20kW charge vs 6.6kW). If you could point out any flaws in my approach, please do.
If you disagree about some part of the previous example at hand ... tell me what that part is.
In my previously posted example ... we used the same ICE for both the pusher and the generator ... which I think is a better apples to apples comparison than mixing different ICEs.
  1. I don't believe we know that the same ICE even has the ability to run an electric generator with sufficient output to offset the consumption of our sample EV at 65mph. I searched and found no examples of a 4cyl TDI being used in this way.
  2. Electrical generators must run at specific RPMs in order to get specific frequency outputs... 1800RPM is the closest but is still not in the peak efficiency portion of the BSFC chart.
  3. The BSFC chart does not tell the whole story... the entire path from ICE to road must be considered. While I agree that the EV components are relatively efficient, the currently available mass-produced EVs are not efficient enough in converting power from the plug to the wheels to allow a (currently available mass-produced) generator to outperform a pusher based on a (commonly available mass-produced) TDI front end from an efficiency perspective... in any situation.
But Otherwise ... without knowing what part you disagree with ... Without evidence or such to counter it ... My position stands as supported by the evidence presented to date as:
Notes about About the ~6.6kw charging limit brought up before about the leaf ... how that effects a range increase is only a factor of the magnitude of that kw of power.
#1> ~6.6kw of pusher power to the wheels will be just as lacking as ~6.6kw of generator power to the wheels.
I haven't researched that, but it is a valid point. However, even in this case I do not believe we can assume that the genset wins.
#2> The ~6.6kw is only in reference to the Leafs slower mode AC-DC on board charge converter ... The Leaf is functionally capable of High power ~60kw charge rates via a 480V 125Amp CHAdeMO compliant fast charging protocol system ... which if you use that system to connect the generator ~60kw is more than enough power.
Yes, I mentioned that, and now we're talking about a generator that is twice as heavy as the pusher, consumes over two times as much fuel per mile, and costs in the range of 10x as much. In my description, I pointed out that even if such a generator only runs for ~30 minutes every hour during the 65mph travel, it's still consuming more fuel per mile than the pusher. And at the same time, you are shortening the life of your battery pack, thereby adding even more cost per mile... so once again, in this situation the genset looses.
#3> The charge rates of the Leaf to the batteries only matter for the amount of generator surplus produced beyond what the vehicle is using in real time ... if you only need 10kw real time , but are producing 12kw at that moment ... than 2kw is all the batteries are getting charged with... even though you are running a 12kw generator.
Errr... I'm not sure I get your point... if you need 14kW real time and have only a 12kW generator, then you're drawing an extra 2kW from the batteries... so what? As I've pointed out many times, the Leaf consumes ~20kWH every hour (on average) when traveling at 65mph. If that's our baseline, and our goal is to extend the range of the EV as far as we want to go, then the generator must be sized to at least offset the consumption... so it has to be at least 20kW. A 20kW generator consumes more fuel per mile than the pusher... so in this situation, the genset still looses.
#4> Keep in mind I doubt the Leaf system would OEM just let you do this ... it would likely require at least some level of modding... it is not OEM designed for generator trailer.
Exactly... there is no off-the-shelf solution regardless of which approach is being taken.
So, still no situation in sight where the genset outperforms the pusher from an efficiency perspective. Pointing to the TDI BSFC chart doesn't give us a fuel tank to miles traveled number for either the pusher or the generator. Saying that the pusher is "less efficient outside the blue area" of the BSFC chart doesn't tell me anything without knowing how that translates to number of miles traveled for that gallon of fuel... and that would be based on what percentage of time (or miles) you expect the pusher to be outside the blue area... and how that compares to a genset approach under the same conditions.
I ask again... is there a real world scenario you can provide where a genset outperforms a pusher? Painting lines on a BSFC chart does not give the whole picture, so pointing to it again won't answer the question.
The Following User Says Thank You to NachtRitter For This Useful Post:
redpoint5 (07-21-2013)
