Old 07-21-2013, 03:18 PM   #20 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
VW uses 4x100 with 12mm bolts, but I'm not sure about the offset. Is the wheel centered on the hub or the lug bolts? I wonder if you held up the one against the other where the interference would be.
The Civic has a hub plate for the wheel, so I assume it is hub centric. But I don't know the center bore sizes. These wheels on my list I have found online mounted by others onto Civics (Miata, Mini, Enkei, Integra), cross referencing with other sites to confirm fitment. I don't recall anyone using spacers. I suppose the Prius wheel is one I should check out some more. Hmmm...
[EDIT: list of sizes with bore info: http://adaptitusa.com/referencebook.htm Center bore for Civics 1992-2005 seems 56.1. Many Minis are identical, some slightly different. Miatas and Prius are listed 54.1.
