Instead of trying to get around pumping losses why not switch to a cycle that benefits from filling the cylinders with as much air as possible?
Making an assumption about what you are implying
All else being equal a CI engine (idealized as constant pressure combustion) is less efficient than a SI engine (idealized as constant volume combustion).
Of course all is not equal and there remains potential in trying to minimise the losses in SI engines.
