Old 07-22-2013, 12:02 PM   #35 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Is the wheel centered on the hub or the lug bolts?
Thanks, freebeard, for this question. It forced me to more rigorously answer the question of center bores. And I discovered that the Miata and Prius wheels I had been listing are 54.1 center bore, while the 1992-2000 Civics were 56.1mm. If I understand correctly that means the Civic wheels can safely be installed on the Miata or Prius (which ring spacer/adapters) but the Miata and Prius wheels cannot be installed on the Civics. The Mini's are a perfect fit. And there are a slew of VW wheels with 57.1 center bores.
Sorry I was mistaken before about a couple of those wheels... perhaps goes to show you don't know what you don't know, always be skeptical, check and recheck specs.
