Thread: 91 civic si
Old 07-22-2013, 03:58 PM   #42 (permalink)
02ws6
If your cooling fan is running all the time then it is killing your mpg. I learned that lesson putting a 160degree thermostat in the trans am. Mileage dropped by almost 30%.
Wire the fan back in factory and put in a toggle switch that'll send power to the fans if it ever gets to running hot. The hf and vx's have an oil cooler/warmer on the back of the block at the oil filter to regulate engine temps. Ran one on my last d16a6 dpfi DX crx and it works very well. I change my oil when it turns from golden brown. After that swap I went from 3500-4500mi to around 7000mi per change. Not to mention it was an automatic car with oversize tires and I could stoll manage 40mpg hwy with regular driving and speeds.
Youre doing work though. Keep it up for sure!
The Following User Says Thank You to 02ws6 For This Useful Post:
Stacygifford (11-20-2013)
