Old 07-22-2013, 04:55 PM   #40 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
54.1 => 56.1mm. That's 1mm of material on each side. Would you take it off the hub or the rim?
I wouldn't put a 54.1mm center bore wheel (like the 1990-1993 Miata) onto a 56.1mm hub plate (like my Civic). Having read a bit more now, I know some of the risks and wouldn't modify either surface for fear of compromising the hub, the wheel, or ending up with dangerous vibration from a poorly balanced wheel. But I understand rings can be used to adapt, for example, a 57.1mm center bore to a 56.1mm hub plate. A one millimeter ring, and I guess its done. That seems more acceptable. Still, best is a direct OEM quality fit. Clearly.
