Guys messing with Hydrogen Boosters and thinking of messing with O2 and MAP sensors...you only need to mess with the Atmospheric or Barometric Pressure sensor. This sensor controls the fuel mix for the altitude for which the car is driven. Put a pot switch on it and turn it so the idle begins to lower (leaning the fuel mix). This way you wont have warning lights and other things to contend with when messing with the O2 and MAP sensors. Your car will just think it is being driven at higher altitude.
Honda...the economical, renewable resource.
