Old 07-24-2013, 10:11 PM   #27 (permalink)
JB3
Work Van - '89 Chevrolet Astro
90 day: 28.43 mpg (US)
240D - '83 mercedes 240D
A fresh set of rear springs will help a lot.
My suburban was sitting so low that the trailer hitch would scrape on some of the steeper curb ramps. It was also riding really rough even with new shocks, wish I had replaced the rear springs years ago.
I put a set of used C20 (3/4 ton 2wd) leaf springs on the rear of my suburban, it rides so much better now. The springs were not factory original to the truck they came out of, they had fresh paint.
With a chin spoiler or air dam the lower the better. Put it as low as possible with out tearing it off.
If you have 15 inch steel wheels you could throw on a set of these:
http://ecomodder.com/forum/showthrea...eel-22003.html
New rear springs are in the works. This van has original fiberglass rear leaf springs, which as the years go by, I get increasingly alarmed that one day they will crack. A company called overland vans carries a replacement upgrade steel leaf set that is bolt on I've been saving towards. Shocks are shot too, definitely looking forward to a new rear suspenion
