Old 07-25-2013, 07:22 AM   #318 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by ausias View Post
So the actual parabolae in torque curve that we see between 1000 to 2250 is not limited by the turbo or ail fuel ratio map. Do you really think is it possible to get so much boost at 1500 rpm?
I'm guessing that you will have an IQ of 55 mg/stroke and 800 mg air/stroke now at 2500 rpm.
Yes limiting factor is not the turbo or engine but how we wanted to make the torque to fit current gearbox. We have also adjusted the turbo vanes to get lower back pressure in higher revs to get more power there. that sacrifices low end torgue and response, thats why we have to wake the turbo with "smoke" at low revs.
So with differend setting more can be made pretty easy. that 280 Nm is there on limits but 200 Nm should not be big problem.
There guys produce from 1.25 liter diesel
270 Nm at 2000rpm
~180nm at 1800 rpm
~130 nm at 1600 rpm
But that is from stock Opel contruction and parts.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
ausias (07-25-2013)
