These are identical in packaging and apparent shape and instructions to the set I received from Raybestos:
Originally Posted by Ecky
But your brake assembly is significantly different in appearance:
I think you have a better fit, most likely. Looking forward to your results.
A test suggestion: Since the improvement if there is one will be too small to measure in FE and since ABA is a bit too tough, how about before and after video of the wheel spinning up on jack stands. Get the wheel to 15 or 20 MPH, hold it, let it glide to a stop. Video the wheel. See if the clips help the wheel spin even half a second longer.
Just a thought.
-james
